wingdiver
Hi
I have decided to fit a new bilge pump and have just bought a Rule 3700 Gold to do the job.
At present I have a massive manually operated pump (the diaphragm must be nearly a foot across!) and a Jabsco electric diaphragm pump, which is OK if more than a little low on capacity if there happened to be a real need - hence the new pump.
Both pumps are plumbed in separately and exit around the level of the waterline via seacocks.
I am adding the new pump rather than replacing the Jabsco as I can see no real need to get rid of it - and there room in the bilge 'sump' for everything. I am also adding a new switch to operate the new pump.
My questions are:
1. Should I plumb the new pump in completely independently of the other two or use one of the other sets of pipework?
2. If independently, any reason why the outlet shouldn't be above the waterline (I don't really want more holes under the waterline than is absolutely necessary)?
3. If I use an existing run, I assume I join up with the pipework after the existing pump rather than before, is that correct?
4. Which is the better of the two existing pump systems to join in with?
5. Would you join with a y-joint or an 'either/or' valve?
6. Would you put any one-way valves in the system?
Thanks in advance.
D
My questions are:
Thanks in advance.
D
