Martin_J
Hmmm.that just took me too long to write on the phone!
why a high water alarm
the pump should have pumped out by that time
all you may need to know is that the pump has run or running
I hope to wire a Whale Supersub to a pump control panel
The panel is expecting a separate float switch, but the supersub has an integral switch.
I'm unsure where the 3 pump wires need to go.
Please would someone help me out.
Therefore on new setup
brown = green
white = blue
black = white
Do these switches only light the "power" lamp when the pump is actually running? I assume so as otherwise there is a battery drain.
Just to acknowledge VicS .... after more than 5 years, this diagram successfully resolved my installation today of a new Whale Supersub. Thanks so much for taking the trouble to sketch it, VicS! What a valuable resource this forum is.Discard float switch A and wire like this:
