Ehbendisdonc
I'm about to fit a manual bilge pump to my Corribee. I would like to bring the 1.5" outlet pipe to a skin fitting within the cockpit footwell (rather than add a through-hull fitting). I would also like to terminate a separate hose with a fitting that would push into that outlet. With this configuration then, the pump would normally discharge into the cockpit but I could also plug in the additional hose and discharge it overboard.
My question is - can this be easily achieved using standard fittings? Has anyone out there done something similar?
