Tim Good
My main bilge pump has decided to not be powerful enough to prime itself and pump the water up and over the anti siphon loop. Here are the facts and see if someone can help:
- voltage under load drops to around 11.8
- cabling is sufficient gauge and connections good
- when in shore power and voltage is increased to over 14 when charging, the pump works and manages to pump enough to get up and over the anti siphon loop
- there is a heck valve within 5 inches of the pump in the bilge
- tested pump in its own and seems to shift a good deal of water.
Thoughts?
Thoughts?
