RogerLS
I have a Rule smart bilge pump which runs only when it has water to pump with a non return valve ( of the usual tricuspid sort) as close to the pump as possible. Unfortunately I cant leave the system to itself as water runs back through the valve, floods the pump and starts it working again. Do you know of a reliable non leaking non return valve. The vertical height from valve to discharge point is about 1.5 metres.
