BelleSerene
I need to replace the Noble Sloop's bilge pump. It's a non-automatic one with an external electronic water sensor in place of a mechanical float switch. It's wired so it constantly detects water and if it finds any, it'll switch on. There's also a switch on my panel so I can over-ride the water sensor and force it on.
I would replace this with a Rule pump with a Water Witch sensor strapped to it.
It seems the new thing to do is to use an 'automatic' bilge pump that turns itself on every few minutes to detect water: [ https://www.marinesuperstore.com/marine-pumps/bilge/rule-automatic-bilge-pump ]. Clearly, for safety this should be wired permanently to +12V, making my bilge pump switch redundant.
Any experienced views on which way to go?
