smithy
Anyone know the life expectancy of a Beta 28hp hi rise exhaust elbow? Should I be taking it off and checking?
... Ive read that the new Beta ones are cast alloy but dont know if that is the case for the hi rise elbow.
I decided to answer my own thread with my findings.
After finding a couple of pin holes in the weld and worrying that it was going to break, I cut the elbow in two. It turned out that the pinholes were just that the rest of the weld was solid. With hindsight I should have ground out the pin holes and welded them up. The inner pipe was also slightly perforated but nothing to worry about.
In the first photo the bad bit of pipe is removed, in the second you can see I welded on a new piece of 316 pipe to replace the perforated section, the third shows the shroud in place ready for welding. Saved the best part of £300
Any thoughts on the achieved lifespan of the Beta 14 'low rise' exhausts...?
well worth doing, even with the cost of getting someone else to weld it up for you.View attachment 62419View attachment 62420
