neil1967
Hi
Getting my Beta BD722 prepared for the winter today. On removing the engine anode 'bolt', there was no anode to be seen (it was there at the begining of the season!). Further dismantling revealed that the anode was lying in the heat exchanger cowling - and although somewhat eroded, presumably not doing a proper job. At the inlet end of the heat exchanger, there was a considerable amount of white powdery gunge (as well as a totally knackered O ring). I have cleaned through the tubes of the heat exchanger, but cannot actually remove the heat exchanger tube from the casing - or at least it has not moved under the gentle pressure I've exerted). Question is, having cleared the heat exchanger tubes, should I worry about the not being able to remove the heat exchanger, or should I just replace the O rings and the anode, on the basis that if there is a decent water flow, there shouldn't be a problem?
Regards
Neil
Regards
Neil
