Portsmouthsailorbloke
Hi All,
I've recently bought a used Beta 20 (yr 2003) with a shallow sump & TM40 gearbox and A-Type panel.
Rigged up with battery and water system in the house garage, it has 3.4ltrs of new 15w-40 engine oil & 0.2ltrs ATF g/box oil and no air filter as yet.
Starts first time, hot or cold, and ticks over smoothly at about 850-900rpm - using a laser tacho reader on the crank pulley.
When I revved up the engine, hot or cold, it didn't seem to reach high revs, so I tested it with my laser tacho reader and it refuses to go beyond 2900 rpm in neutral gear. The peak 20hp output is reached at 3600rpm, which I can't achieve. The chap I bought it off says that it will reach max revs with the gearbox removed and that his other Beta 20 and his mate's Beta 20 do the same.
I've yet to try the revs thing with the g/box on in gear, forward and reverse. Any one else found this to be the case?
Peter
Peter
