Burnham Bob
I previously posted a problem I was having with draining the coolant from my beta 14. I removed the tap but nothing came out. Consensus was that crud accumulates in the elbow.
Advice from Beta via email was to drain by disconnecting the hose at the bottom. However at the Boat show the Beta staff told me this would not drain the block fully.
Some forumites had used wire with varying degrees of successs and there was some advice to remove the elbow to make poking easier - but I found the engine mounts get in the way.
However this morning, with the tap removed a bit of wire poked down the elbow resulted almost instantly in a flow of coolant - not sure it even went round the corner of the elbow.
So, for other forumites who had the same problem I'm reporting back that mine was solved easily with the wire and I need not have worried.
