Best torch with bracket to always find in emergency
tudorsailor
12 Jun 2005
London
zebahdy.blogspot.co.uk
I read this months articles YM about sinking. One article mentioned sinking due to being unable to find a torch in the dark. In a crisis a torch that is "usually" on the shelf above the chart table will not be there. Surely what I need is a torch that is kept in a bracket. However. very few torches come with brackets. What torch complete with bracket do forumites recommend?
TudorDoc
shmoo
23 May 2005
West Cornwall
We have a heavy metal bardic* lamp of dubious origin, with non-slip mat glued to the base kept on the cabin sole beneath the bottom step. It’s ALWAYS there or I kill people.
It is never used for routine lamp duties. Only for 5 seconds or so coming in in the dark to find the main switch and emergencies. Shows red and green also if needed.
* Google or ebay for details
shmoo
23 May 2005
West Cornwall
Can you still get those square batteries?
Yup, and they last a long time. In my experience its the so call "switches" that go on torches. Bardic lamp switches seem pretty reliable.
whipper_snapper
9 Aug 2006
Kenya
Effectively for ever. I have had them flashing for 6 months so far. And of course you can turn them off with the original maglite switch which is still functional but is normally left on in flash mode.
You can buy little plastic push clips from any chandlery that happen to hold the torch perfectly.
boguing
5 Nov 2005
Styx Marina
And to add the MagLite support - they have a lifetime warranty on all but the bulb. Took a getting on for 20 year old one in to my favourite toolshop to ask if it could be sent off for a new switch? Don't worry, Sir. Here's a new one. Fantastic. I now have five.
mikemonty
17 Mar 2005
"Have a powerful torch available" they said:
So I bought a £16 3,500,000 candlepower B&Q special.
You can always find them in B&Q, theres a pile of bodies with blackened stumps where the heads used to be - people will look into them when switching them on.
Can charge off a 12v cig lighter socket (2 sealed 6v lead acids in series)
Don't have a bracket, but do have a strap and a stand.
Apart from dubious to no waterproofing seem about ideal to me.
Mike
Maglite..
.. is always in my pocket.
There are other torches around the place, one next to the chart table, another in our sleeping cabin but the Minimaglite is ALWAYS in my pocket.
Steve Cronin
Robin
30 May 2001
high and dry on north island
We too favour Maglites and have 2 largish ones with 2 x D cells mounted in plastic springy clips inside the locker on the end of our chart table. They are pretty well bullet proof but both of ours did 'fail' over last winter, traced to a little corrosion in the threads of the screwcap on the battery compartment, easily cleaned. We also have a small AA battery sized Maglite in the grab bag and another pocket one if needs be for walks in the dark ashore. We also have a cheapo waterproof headlamp from Homebase, about £6 I think that lives in a tray by the nav table and has really earned it's keep.
Best place to buy Maglites is Wal-Mart in the USA if you are over there, about half UK prices.
whipper_snapper
9 Aug 2006
Kenya
I suggested a modified AA Maglite with a flashing LED for use below. On my last boat we had one clipped above the chart table and one on the forward bulkhead. The flashing LEDs make them perfect to find in the dark, but I suspect it makes them less waterproof. They were for moving around below without disturbing sleeping crew. I would not carry one in my oilskins pocket, as they would be sitting in a pool of water (and slowly dissolving Werther's Originals) which would, I suspect, be terminal.
We also had two unmodified D-cell Maglites clipped strategically either side of the companionway. Clips which fit them perfectly are easy to find.
ShipsWoofy
10 Sep 2004
another mag-light fan
