Norman_E
One assumes the reefing line goes to the aft end of the boom, therefore there is a large backwards component to the pull, which increases as the cringle gets closer to the boom.
Actually the backward component gets less as the cringle approaches the boom if the tie round the boom is too far forward. In explanation there is equal tension on the rope either side of the point where it passes through the cringle. That is why I suggested tying the bitter end back to the boom end to keep the tie round the boom a little behind the point where the cringle would touch the boom. That way there should be no problem in getting some foot tension to flatten the sail.
P.S. The real issue is that the wind on the sail is trying to belly it out, putting a big force on the sail trying to pull the clew (i.e the reefing cringle) forwards. That force is therefore trying to slide the tie round the boom forwards and if it does so you cannot flatten the sail by pulling the reefing line.
