Best hole saw for GRP?
Han_solo
27 Sep 2018
I need to cut a couple of 20mm holes in GRP that I have to cut from the gelcoat side. Is it best to use the standard toothed hole cutters that you'd use on wood or is it better to use the diamond tipped ones to avoid chipping the gelcoat?
Cheers.
Whichever hole cutter you decide on, drill the pilot hole first then run the hole cutter in reverse until you get through the gelcoat. This method does not chip the gelcoat.
