PotatoNavigator
Yes you can use Sika underwater but you will find CT1 will last much longer. I have used both on keel joints and Sika barely lasted a year whereas CT1 never needed replaced.
Good to know, ta.
If the GRP is that thin why not through bolt it with countersunk m4 screws.
I'd like to, it would be my first choice...but as I said earlier, the floor in the forepeak, isn't directly behind the hole I'd be drilling through the keel-line...so it's not possible to blank-off the inside where the bolt would come through. Quite apart from the difficulty of securing the bolt inside, there would be flooded sections of hull-cavity and a continuation of my leak problem. Plus, the keel-band is only 9mm wide...put a 4mm dia hole through that, and I'd be picking the pieces off the slipway before the first launch.
I really didn't choose glue out of faith or preference - but because drilling holes has definitely not worked. Frankly I'll prefer to risk having the glued keel band drop off, than have the leaking screw-holes as an ongoing problem.
Thanks for the ideas though.
Thanks, Vic...but I'm inclined to hope I can solve the problem by the way I haven't tried, after definitely failing by the way I have.
It seems to me a very odd way to construct a boat - using thin GRP at the keel join. I think there is one of those hollow 'ribs' along the keel, strong enough for its principal purpose of stiffening the hull, but very vulnerable to puncturing by the keel-band screws. And somewhere along the length of the hollow 'rib' are other holes, allowing the water gradually to flood the forward chamber.
There's nothing to stop me using screws above the waterline, all the way up the bow. Hopefully that'll save the brass from sinking if the glue does fail.
The same could be said for Sikaflex 291 and Puraflex 40, but I assume there is no big rush?
No great rush; but while I'm a fan of Sikaflex for sealing, I know well that 291i isn't primarily an adhesive, so I won't try that.
It only occurred to me since starting this thread, that the keel of the boat is gelcoat rather than GRP...will that make any difference?
I wonder if there'd be any value in drilling lots of shallow diagonal holes in alternating directions, into the flat side of the brass strip, in order that when the adhesive cures, it would effectively form dozens of little locking barbs, rather than just a flat slippy surface?
Tell that to the fittings on my boat! Getting anything apart that has been attached with Sikaflex 291 is an appreciable job, as is often discussed in these pages. I have seen a keel that was attached with Sikaflex that, after having all its bolts removed, took considerable attention with big hammers and wedges before it could be persuaded to detach.
