Greenheart
I've been here before...asked the question and took some of the advice given, and regretted it, but there seems to be such an aversion to old threads being woken out of the archives, I thought I'd start fresh and get some new ideas.
Keel band. Made of semicircular-section brass, 3/8 of an inch across. Conventionally it ought to be screwed on to the Osprey's keel line, but I tried that and have concluded that it's wholly unsatisfactory...
...partly because drilling countersunk holes in a brass strip that narrow, weakens it badly; partly because attaching it to the hull every few inches, leaves most of it vulnerable to exactly the kind of damage which it is meant to prevent...
...and partly (alright, mainly) because the GRP along the Osprey's keel-line seems to be so thin that the tiny screws go right through the floor of the big forward compartment ahead of the mast, and in the course of a long day-sail, several gallons leak into what is meant to be a perfectly dry chamber. So, no more screws...
...but which of all the available glues will do instead? It must do many things - resist sudden sharp knocks, endure being drenched for long periods, and critically, it must bond brass to GRP or gelcoat as I daresay the keel-line is.
And how does one abrade or 'pickle' the brass chemically, to give the glue a better grip on it? Thanks for reading. :encouragement:
