RupertW
Fine with heavy 3m rib but needs 80 percent power in a chop with 4 people and bags. Normally use 30 to 40 percent in an anchorage.
Whats the charging regime like for a Torqueedo ? How long do you get for each charge and how many amps does the charge consume ?
Thanks to everyone for your replies.
Quite a lot of consensus which is good!
Looks like max size which will fit on foredeck, with large tubes, is the way to go
I think I prefer the idea of a solid floor (ie RIB) rather than airbed, more robust maybe.
Thanks again
Can highly recommend the Suzuki 2.5 outboard. I can carry it! It's easy to lift on and off and I believe the lightest for its size other than the electric outboard. We also considered them but as we spent so little time anywhere with mains couldn't rely on being able to charge it.
I think we will be going for something we can keep inflated on the coachroof/foredeck, which doesn't compromise our sailing, and which we can lift on and off the boat using a halyard.
I think we replaced our breather strip after 2 years from Suzuki. Easy to replace.
