VicS
Des Modromic ?
Is that the fella who used to present Countdown?
YOU CANT HAVE PUSHRODS
AND
A
TIMING CHAIN
OR
A
CAMBELT.
MUTUALLY EXCLUSIVE FEATURES.
I quoted your message. What you said was (in capitals) "YOU CAN'T HAVE PUSHRODS AND A TIMING CHAIN ...........MUTUALLY EXCLUSIVE FEATURES".
Sorry, but you were wrong - not much to misunderstand there - and I'm sure neither of us would want AJ 305 to be confused when he's in trouble over his engine.
The timing chain obviously refers (as does a timing belt) to an OHC engine...
VicMaybe that does not read as you intend it to.
You have a camshaft, be it an overhead one or not and something must drive it. An overhead one can be chain driven or belt driven.
An OHV camshaft is frequently chain driven but can be gear driven. Cannot think of a belt driven one but there is no reason technically why it should not be.
Push rods mean it's OHV not an OHC.
I think as suggested you have to check the camshaft timing but I doubt if you'll find it wrong.
Pretty certain that the problem will have been caused by sticking valves.
Whether or not they have been struck by a piston is another matter. It may or may not be possible. Always is possible with a diesel engine but not necessarily so in a gasoline engine. Depends on engine design.
Also perhaps be checking for broken valve springs.
A Boatmike says its a strip down job until the likely cause is found.
Ill agree with what Vic MEANT to say, normal pushrod engines dont use cambelts. Our MD22s dont have pushrods. I suspect what he said originally, seized valves OR rockers. Ive straightened pushrods out in an emergency before now. I would take the rockers off, check they are free and if so get a hammer and use the stale to push each of the valves to see if they moved, bearing in mind that some of the cylinders could be on top dead centre stopping the valves moving, in which case turn the engine over a touch to check. If he can get them moving, maybe lube them as well, then straighten the pushrods and assemble temp to run it to check all is working before lashing out on new bitsAnother option is that one of the cam lobes, or followers has failed.....
But I stick by my early suspicions.... I'd start with the timing belt....
Not sure I see how a locked piston can lead to bent push rods !
I am tempted to suggest engine running cold or only run for short periods causes condensation under the rocker cover. That leads to rust on the valve stems, they fail to open freely and the consequence is bent push rods.
I will believe just this once that you misunderstood me. Suggest reading a little more closely.
Thats why I called it an overhead valve engine. The camshafts on those are *usually* driven by gear off the crankshaft.
Happily we haven't introduced Desmodromic valve gear intot his conversation, nor yet hydraulic tappets.
OK lets get away from the piss ing contests, the only way that the rods can bend is if the camshaft is pushing the rod and there is something stopping the rod moving at the other end! Either the rocker is not moving or or the valve is not moving, thats it! Your mission is to find out which, then to find out why. Forget the bollox of water in the cylinders, if there was water in there the piston would stop moving, the crank would be stopped and consequently the camshaft would be stopped and no movement of the pushrod would occur, therefore no bend ( I dont know why I am explaining this, the most elementary description of how an internal combustion engine works!) Thats it seemples!!Hi guys thanks for all the responses v helpful.
Removed exhaust manifold and riser today appears to be the original and has signs of water leakage. Removed plugs and turned engine over just to remove any water that may of been sitting in cylinders, gave a good dose of WD as well. So am thinking leaking exhaust manifold maybe corroded exhaust valve and seized it solid, but how would this explain the bent intake push rods. Appears to be no water in cylinders so can rule out hydralic lock, also engine was still running ok, so am thinking timing is still ok.
Stu
Its a V8 petrol engine. Whats the perkins got to do with it?Perkins 4107 and 4108 do the same from time to time, that is bending pushrods. Usually the cause is one of two reasons.
Firstly a broken camshaft follower, which is unlikely to be broken x 3 times at the same instant so to speak. So it may be a camshaft timing problem.
The second cause on the Perkins is corrosion and seizing of the rocker assembly. This usually occurs if the engine is left for a long period, lacks lubrication to the rockers or there is water in the engine oil.
If I were you I would check the free movement of all the rockers, and then if they are OK, look at the bottom half of the engine
Id already said that while everybody else was going on about how clever they are!Calm down Stu, we're all just trying to help and eliminate problems.
OP- Examining the valves / rockers on that engine are pretty simple so i'd strip that area back and check all is free-moving
I despair sometimes, grump grump!!
Stu
