wonkywinch
Considering the French word for water features heavily in the makers name, you would have thought Beneteau would get it right. Our boat is 9 years old and I still find issues with her.
I'd never been happy with the water flow, the pump always seemed noisy and so I decided to fit a new Shurflow pump for improved pressure and lower noise. I had always wondered why there was a non return valve straight after the manifold before the pump filter on the suction side.
Since we already had an NRV in the correct place, ie cold water input to the calorifier, I decided to remove it as part of my refit. Once the job was done, the tap & shower ran really well, the pump was a fair bit quieter than the old one but on closer inspection, I found a load of blue plastic swarf in a mesh filter inside the NRV. My guess is this has been there since Beneteau drilled the (blue plastic) tanks when the boat was being built.
The old pump worked well but short of refitting it to see how it really performs vs the new one, I've put it up for sale. Here was the work.
Before:
New pump fitted together with recommended use of flexi hose to connect the pump.
Suggested boat water schematic found online:
NRV already fitted to calorifier input ..
Original NRV in inlet line removed and cleaned out -
I didn't think to remove and check the manifold NRV before going ahead with a new pump! What purpose it would ever serve in that location beat me.
Perfectly serviceable Jabsco pump up in the For Sale section - https://forums.ybw.com/threads/jabs...model-32600-7006-12-volt-30psi-2-1bar.622071/
Before:
