ChiPete
The Beneteau handbook (for the 393) under maintenence of your boat, states the following in relation to general hull maintenance:
"Do not wash with pressure machine using water warmer than 21 degrees C
Do not use pressure excess of 150 Bar. (2175 PSI) when using a high pressure spray wash.
Do not hold Nozzle closer than 10cms (4 inches) to surface of hull
We believe the above points to be pertinent to all GRP boats."
Thanks for that, I'll dig out the manual for our 323 and check what it says.
In any case, the water definitely wasn't above 21 degrees (this was at Chi Marina a week ago not Marbella!), the washer is rated to only 120 bar and I'm confident I wasn't holding it too close. Thinking about the wording, it would seem that it might be an attempt at a ''get-out'' clause...cynical? Moi?
