Binman
Have a look on utube, blokes doing a long piece in a polythene bag, very easy, I would try that route if I ever needed to.
You can steam timber 4 inches thick with wallpaper steamers and wrapped in thick polythene provided you use more than one steamer, insulate the package well, and wait long enough. As was done on this job.The wallpaper steamer would produce the similar results when connected to your drainpipe. Probably not got the oomph for large bits of timber but enough for anything that doesn't require a proper steam box.
An hour for inch thick iroko should be sufficient. Longer won't help if you've had a good flow of steam and good insulation. The essential thing is the speed of working - you need to get the wood bent to shape as quickly as possible. For your job you would have been better to make a former (somebody suggested poles in the ground) so that you could have trapped one end and then bent the other end immediately to shape, worrying about intermediate clamps later. The wood will always spring back as it cools, so a bit of overbending on the former is a good idea.I would like to know if hard wood like Iroko or Teak would become more supple with a longer steaming time?
Just a short update on my previous post about replacing 2x1, 6ft length of iroko gunwale.
As I said, I steamed it for nearly two hours in a piece of pipe, it seemed to be working well as steam was gushing out of the hole drilled in the far end, even then when removed it was not that pliable. By the time I had finished clamping it into place (about twenty minutes) the wood had gone cold, nonetheless it was a good fit.
On Friday, after eight days in place I removed it in preparation for epoxying into place, whilst it had a bit of form it still needed a bit of coaxing to get it to bend on.
The job looks good, but I think we could have achieved the same result without steaming.
