Graham_Wright
For my pulpit I need a semi-circular bend with a 10" radius. My own attempts with a home made bender have not been a great success. This uses a half pulley with a 1" groove and two side plastic pulleys also with 1" grooves. The result is not bad but there are slight wrinkles on the inside.
The ideal tool is a ring bender and there are two in my region but neither can pull the required radius.
Suggestions have been filling with wet sand, filling with dry sand and filling with (perfectly) dry sand and welding up the ends.
The problem with an ordinary bender is that the outside is stretched and the inside compressed. A ring bender overcomes this by stretching the outside of the bend and not compressing the inside.
Any other suggestion would be very welcome.
The tube is 1" OD with a 2mm wall.
