Bending Stainless Tube
I realise it's a new concept for you Roger, but just for once, try reading what's been posted.
Let me help you, here's what i actually posted, i've made some text a little better, so you don't miss it:
"We used to bend 1 1/4" T45 aircraft tube with mine. Needed three people hanging off of a 2m scaffold tube to do it, we had to bolt the bender to the floor, and i'm not exaggerating.
I bent some handrails for may previous boat, from 1" 16g stainless, using a 1m tube extension on the handle, on my own, with the bender not bolted down, easy as pie. "
See above, if you need bigger text, let me know.
One last time, not bolted down for 1" stainless. My bender has a set of heavy steel formers and with the bender bolted down for 1 1/4" T45 (not stainless, stainless is like bending cheese compared to T45) and three people on a scaffold tube, the bender tubes did not bend.
I'm not the only one to have bent 1" stainless with the old Hilmor bender, see post #21
Being a relative newcomer to the forum, it is apparent that mostly every subject you care to comment on descends into a slanging match sooner or later. Why?
