superheat6k
I need to make a mast support bracket to hold my radar mast safely at an angle when down to allow me passage under Bursledon Bridge.
I need to make or have made a semi circular section of stainless tube 20 - 25mm diameter with an inside radius of ~200mm, and with straight tails on each side of the semi circle. I reckon a 500mm piece will turn about right with tails the correct length I require.
Any advice on how to achieve a neat turn and what wall thickness I should choose gratefully received.
Do I heat SS like I would to turn a heavy copper or steel pipe ?
Does polished SS discolour permanently after applying oxy-acetylene heat ?
