Cliveshep
Just get into and use it. It will be much safer than an angle grinder.
If it is old you may find the edges of the wheels are not flat but perhaps have a groove or low area in the middle. This doesn't matter so much if you are just grinding or smoothing metal. Move the job from side to side and with use you may get it flatter. If not then you might need the dressing tool. You need it flat for drill bits. New stone wheels are not so expensive and can be bought for all sorts of jobs.
Sharpening drills is easy. The trick is to start with a large drill 8 or 10mm that is in fairly good condition. Look closely you will see the cutting edge and angle. You grind the whole face ie edge and angle to improve the cutting edge. Note that the cutting edge must extend right out to the outside edge. They often wear on the outside where they have been used to make a hole bigger. The grinder will take a lot of metal off quickly so just a short touch then check. Keep the drill cool as already said by dipping in water.
good luck olewill
Just to add to this excellent and informative post - "clearance. clearance, clearance" meaning that with any edge cutting tool, milling bit, drill bit, lathe cutter, the proudest part must always be the cutting edge, with a clearance slope away from this. Otherwise the tool will just polish itself and make the work hot. The exception is drill bits used for countersinking aluminium.
