Graham_Wright
That should be interpreted as distress.If they change course and still endanger you - this is the time to use the parachute flare - aimed at bridge height but not at the bridge.
Jonathan
White maybe.
Jonathan
Sounds good - what sort are they?We have a couple of powerful led deck lights that light up out superstructure. The front one shines a long way forward lighting up the bow and the sea in front of the boat. This one was positioned like this to allow us to set the anchor at night or pick up a mooring. The rear facing light shines on the stern boarding ladder. This allows us to easily get in and out of the dinghy in the dark. The result of having these deck lights on at night under sail is the sails are very well lit up making us very visible.
Having deck lights that just point downwards does not do the same job. I know, because that what I had previously. It's a cheap and effective addition to any boat sailing at night
I can't remember where I purchased them. They have been up there a number of years.Sounds good - what sort are they?
And you could spend your whole passage pretending to be a N Cardinal mark that’s adrift.If I could afford it I would get a light aircraft strobe up top . Have you seen how they grab your eyes ?
.....If they change course and still endanger you - this is the time to use the parachute flare - aimed at bridge height but not at the bridge......
Jonathan
'Parachute flares must be discharged vertically upwards. If there is a significant wind blowing, add a little downwind angle to get the greatest height' is a summary of the instructions I have read on all parachute flares.
You can't 'aim them at bridge height'. How would you 'aim' them anyway? Look along the tube?
They won't do what you expect at near-horizontal angles.
This advice is wrong and risky.
I have discharged lots of flares in the wrong way, to see what happens. Advice to aim rockets anywhere, apart from upwards, is wrong and dangerous.Try it before you condemn it.
I lived in a jurisdiction where using out of date flares was a common practice - and have used parachute flares, surprisingly frequently.
Jonathan
Perhaps 40 years ago I met a sailor who had sailed over from Canada, he had attached a white strobe light for an aircraft to the top of his mast. Apparently it was very effective.
I've found that loss of night vision only lasts for 20secs or so.You do not have to shine the torch into your face, You will only frighten the kids. You aim it at the sail & do not look up at it while you are doing it. In the 70s in a small yacht, with poor battery power & useless nav lights, it was a very common procedure to light up the sails. I never recall losing vision. However, having a crew there would always be one of us with the sense to look the other way.
I think that is generally true, but it depends on how long the light lasts for. A chemical process takes place during dark adaptation and this takes about 40 mins for full effect, so you don’t want to go through all that again.I've found that loss of night vision only lasts for 20secs or so.
Goodness. I must have have a different Mark I eyeball. It takes me 20 minutes to get proper night vision.I've found that loss of night vision only lasts for 20secs or so.
