CalicoJack
The engine is a Perkins 4108. I want to replace the bearing on the Jabsco raw water pump. I went to Kent Bearings and they could not match it. The numbers on the old bearing are RHP England then of course the crucial bit, which has a wear mark on it but could be 55D IS KDD.
The dimensions are outside diameter 35mm, shaft diameter 15.83mm and width 15.80mm.
Any thoughts on sourcing on of these?
Nigel
Nigel
