mikegunn
To all electrical experts, and others.
When away from shore power and during daylight my sailboat’s batteries can receive a charge from two sources.
(1) Solar panels which charge at a rate determined by an algorithm in a sophisticated MPPT controller.
(2) When under power, the engine’s alternator which relies on an unsophisticated internal regulator to determine its charging current.
My question is;
If both sources of a charge are active and the MPPT controller applies a voltage that is higher than the alternator’s output voltage, could the alternator’s regulator be fooled into thinking that the battery is full? Resulting in the alternator significantly reducing its output even though the batteries are still hungry.
Mike
My question is;
Mike
