westhinder
Is the water from a domestic tumble dryer pure enough to use to top up lead-acid batteries, or does it contain too many impurities?
It indistinguishable from distilled or de-ionised water, other by detailed scientific analysis and is perfect for batteries, radiators, irons, windscreen washers etc.
Richard
OP's asking about water from a tumble dryer not a fridge freezer, where does the pure water come from?
In my experience, the condensate from tumble dryers can contain tiny fibres, so probably best not to use it for batteries.
This was the niggle behind my question.
I know in theory it is pure, but what about microfibres?
From the answers so far opinions seem to vary, I am still hoping to find an answer based on facts. It does seem a pity to pour pure distilled water down the drain.
How much topping-up do your batteries need??
Not much. I check them at the start and the end of the season and at the start of and halfway through the summer cruise when they will be worked hardest. Never more than a few mm top-up needed.
The question came from the fact I had to run the tumble dryer four times today and poured a couple of litres down the drain.
I don't understand. I never mentioned fridge freezers.
The condensate from a tumble dryer is just condensed water vapour which I've found is purer than the melted ice from a freezer. Our AEG tumble dryer produces crystal clear condensate and I keep a 20L polykeg of it in the garage.
Richard
You could get a water butt, put the tumble dryer condensate into that, then use it on your garden.
Distilled water is not goo for plants
#2 mentioned fridge freezer water. Not had a tumble dryer for many years but I remember the old one usually had some fluff which had got around the filter to the condensate tank so I wouldn't call it pure without fine filtering.
Distilled water is not goo for plants (or drinking)
Richard
No good for plants because it contains no nutrients perhaps ? ............ like rainwater !
The lab where I worked some 30 or so years ago always made the tea and coffee with demineralised water because there was no drinking water supply.
I suspect my Brita filter produces water very low in dissolved solids, but I have never analysed it. I use it for tea and coffee because it does not scale the kettle. Analysis may well skow that it is Ok for batteries.
Richard suggests that condensate from a tumble dryer is indistinguishable from distilled or deionised water other than by scientific analysis. So is tap water, therefore use tap water![]()
