TiggerToo
The cable terminals hooked onto Tigger's battery terminals look a bit messy. No corrosion but the copper filament are untidily and partly severed (they probably did not fit properly into the terminals).
Is this a problem? Would I be better of using a "proper" soldered & crimped terminal - or should I stick with tthe screwed/bolted ones?
