jcwads
Hi All
Another novice question, probably my 100th so far...
On starting my T40 last week the Port engine started fine, but the Starboard engine was not starting so flat battery I assume. Used the switch on the dash to give juice from the port battery to starboard and it fired up.
Kept an eye on it for the day and it was still slow to start up even after using the boat all day. I dont know the set up yet on my T40 but I am assuming that the Starboard battery is potentially providing the power for the domestics?
The boat was on shore power and has a battery charger. I had left my kitchen fridge on, but would have thought the charger would take care of not draining the batteries..
So I am now left with the question of whether the batteries are knackered or it is something else. Such as a connection issue or the alternator not doing its thing.
The battery charger was fitted new in 2016 from looking at the history. Also the batteries were new in 2016. They look expensive so would it be normal for them to pack up in less than 2 years? Pic attached.
Any thoughts, ideas or advice welcome! The genset is also dead to the world. It was working when I did the sea trial and survey, but no power at all so not sure if that is related?
Cheers
Jonathan
Cheers
Jonathan
