julians
can a battery go from being able to start an engine just fine, to not being able to even turn it over 12 hours later, without anything draining it in those 12 hours? Ie is it possible for a battery to fail overnight?
Ive been out in majorca over the weekend, using the boat as usual. For the first 3 days the boat has been starting on the button no problem, but then on day 4 when i went to start the engine there was not enough power in the battery to turn it over, i had to link up to the service battery to start the engine.
Once started we ran for an hour or two,then turned off the engine, then immediately tried to restart using the engine starting battery only, and again it wouldnt turn over at all. Linking up to the service battery enabled me to start the engine. It seems the engine starting battery has just died overnight. Voltage from the alternator looks good.
For background the boat has a single engine,and two batteries,one is purely used for starting the engine, the other is used for powering the accesories (fridge etc) , i have a switch that enables me to link the batteries together to start the engine (or power the accessories) if one battery fails. Normally i keep the batteries separated. Both batteries are approx 5 years old, and are connected to a mastervolt charger when to boat is left for any period longer than a few days.
