Neeves
Ours is 'similar' but the shunts look identical. Our display is circular rather than rectangular. There are a number of suppliers of 'similar' products - I think they are different suppliers as their displays are different, different shape and different display colours. Oddly none of them define who actually makes them (so they could be made by the same company). Historically this was common, everything was simply defined as 'Made in China'. But they have become more brand conscious so the absence of a manufacturer is - odd.I assume your battery monitor is something like this:
Battery Monitor 50A/100A/350A VOLT Capacity Tester Voltmeter Ammeter DC 80V | eBay
As well as the wires going from the actual shunt resistance to the meter head, there seems to be an isolated terminal for a sense wire from the +ve terminal of the battery. This would go to the meter head unit via the same screened multi-way cable as the current sense lines. It probably powers the meter head as well as allowing the head unit to measure the battery volts.
That +ve wire should have a fuse in it near the battery.
The name 'shunt' for a parallel current path is long established, it's probably related to a railway shunting yard where you have lots of parallel tracks to sort goods wagons?
Rather than the colloquial term for a collision between vehicles.
As well as being a term for a current sensor, it can be an adjective for any component in parallel.
You can buy through Aliexpress who we have found reliable - if things go wrong they honour their promises. We bought this kit through Temu as they ship from Oz and so far have been fast and reliable. In the past we have bought much direct from factories in China, we ran a business selling into China and have the linguistic skills - but Aliexpress and now Temu (who operate in the UK but certainly US) have made it easier
The meter is supplied with a short screened cable but they also supply a 1m extension, shown in the ad. The screened cable (shown in the ad) with the small rectangular plug connects to the white female socket on the shunt. We don't need the extension cable as the shunt is next to the meter. The sense wire runs from the positive pole of the battery to one of those 2 little grub screws or the the green socket on the shunt (it has two even smaller grub screws to secure the sense wire). There is no reason provided why there are effectively 4 different locations on the shunt for the sense wire. I made up the sense wire this afternoon but have not attached it yet. The connections of the sense wire to the shunt are decidedly fiddly, tiny, and I have the shunt attached to a panel, with the display above, and I'll need to take the shunt off to connect.
The main positive cable has 80 amp circuit breaker about 0.5m from the battery - I think you might be saying this is inadequate, too slow or not near enough...? I assume you refer to a 'T' fuse (not any old fuse).
Primary charging is solar with the facility to use a B2B off an alternator.
The problem is that I have no way of knowing the state of charge on the battery, hence the meter. I can read volts and amps but they don't tell me state of capacity.
Thanks for your input and for the background on the word shunt. Oddly the Chinese call it a 'Sampler' - as in 'it samples data'.
Jonathan
