Hadenough
I currently have two domestic 110AH and one 85AH, 700A main engine cranking battery through the usual 1/2/BOTH switch. I also have built in 4KVA generator with its own 400A starter battery and a 50A "intelligent" inverter/charger.
I have to change the domestic and main engine batteries and am thinking of (and have space to fit) fitting three 142AH lead acid batteries and while not on passage, leaving the selector switch permanently to BOTH to maximise the domestic bank. We will be living aboard mostly on a swinging mooring or at anchor so the management plan will be to run the generator daily to keep the batteries charged and provide hot water. The generator charges its own battery. When I need to start the main engine I also propose to use the whole bank via BOTH. My logic is that as we will be aboard to monitor and manage the batteries why keep a big chunk of the battery capacity in reserve just for engine starting. Especially as I can still start the generator independantly from its own battery and recharge the main bank.
While on passage under sail I plan to revert to the usual domestic / engine battery split to maintain a reserve for emergency engine starting.
Goes against the grain and I'm not sure yet, what's the view??
