Balbas
We're just back from a fantastic family cruise in our new (to us, but actually 45 yr old) boat, during which I managed to completely drain the (single) domestic battery. We've finished our cruise and I'm trying to breathe life back into it with a smart charger - but that's by the by.
When starting, obviously I was switching to engine battery to start - to me it then makes sense to switch to 'both' in order to charge both batteries - is this correct?
When charging - noting that the (single) domestic battery was completely flat - the voltage at the terminals was never rising to the dizzy heights of 13v, staying more in a 12.5-12.7v range (admittedly I only ran the engine for 30 minutes or so at anchor, as the noise inside was quite annoying) - am I likely to have a goosed alternator, or is this a function of the battery being completely and utterly wiped out? How do I test the alternator in isolation?
As an aside, the rev counter (which I believe is run off the back of the alternator) is intermittent at best and I notice on this cruise that the hour meter has stopped ticking - I assume that's also likely driven by a signal from the back of the alternator? Its a Vetus 4.14 if that makes a difference.
Finally, I will be installing a larger domestic bank - I've space already for 2 batteries and may add a further 2. Hopefully this will reduce the likelihood of completely banjaxing the domestic batteries - and I'm also considering adding a solar panel - a 50W one would fit on the cover for the sliding hatch - how effective are these in UK weather? I would fit a wind turbine, but we have a ketch, so there's not much space.
