pcatterall
Following my last post on 'ghost voltage' I have been trying to sort out the wiring especially as there was an obvious drain even when everything was switched off!! ( partly down to the leak to the starter motor detailed below)
I still found some other losses but am uncertain as to their significance as I am usless with my multimeter.
With it set on 10amps there was no drain in evidence.
Using the 200m scale(what is that?) I had a reading of 3.8 with the battery switch off and 40 with it on ( all equipment switched off) I cleaned and dried all the battery tops, the bus bar and all the main connections and then measured ( 200m scale) 0.0 with battery switch off and 7.00 with it on ( all leads on the bus bar disconnected.
When I connected the bus bar leads I believe that due to the drain to the starter ( below) that I may have upset my multimeter as it dont work no more!!
One observation is that although the battery tops were not too dirty I think I could see evidence of 'tracking' to the positive terminal. I am at a loss to see where the reading of 7 comes from unless the on/off/on switch has some sort of 'leak'
Any ideas from you experts and can you explain those current symbols ( 200m = 200 milliamps?? or what)
Many thanks and appologies for 3 posts!!
