Dino
Hi,
I bought a boat earlier this year and I have been relying on running the engine to top up the batteries. It has a standard lead acid 110ah cranking battery and an Elecsol Deep Cycle 115ah Carbon Fibre Domestic battery. At the moment I just have a basic 8A manual battery charger. I have brought the batteries home to give them a good charge. Is this charger sufficient to charge these batteries fully.
Both batteries were below 12V when I put the multimeter across them. I charged the Elecsol for approx 16 hours but the charge only came up to 13V. I read that these batteries should come up to 14.4V and a standard lead acid to 14.8V. Is that correct?
What is the best way to charge them and what charging voltage should be used? Should I use the high or low setting on my charger?
