Leighb
I have a problem with my alternator charging.
System consists of 2 110AH domestic batteries and an 85AH start battery. They are sealed lead acid type, so not possible to top up.
Charge is split by a BlueSea systems VSR there is a separate BEP switch for each battery and another to emergency parallel both banks.
This system worked fine with my old engine, this year I have had a new Beta 20 fitted with a 70A alternator.
I now find that when the domestic battery had been discharged a bit - after a day or two away from shore power, when I run the engine the VSR does not charge the domestic batteries at all. If I parallel the batteries then the domestic batteries get charged - as you would expect.
I thought that the VSR was perhaps faulty and got the electrical chap who installed it all to check it out. He found that the VSR was working perfectly, but that the alternator was putting out 14.82V, measured at the battery.
He said that the problem was that this is higher than the overvoltage disconnect setting thus preventing any connection to the domestic batteries.
He said this overvoltage limit could be increased allowing normal working, but that prolonged charging at this voltage could damage the batteries and affect their life. He suggests that the alternator regulator may be faulty. I have contacted Beta who are thinking about it.
Do the electrical experts on the forum agree with my electrical engineer or would it be OK to just increase the setting on the VSR?
