wakeup
Hi,
I have just replaced my starter and domestic batteries with 1x115ah starter and 2x115ah domestics.
The batteries are lead (openable) type not sealed nor gel and are manufactured by Numax (labelled deep cycle)
Both banks are connected to the same battery charger. Reading the configuration guide there are dip switch settings for the type of battery and those settings in turn set the input voltage during the boost and absorption phase.
The voltage input options are 15.1v (for lead tin delphi delco whatever they are?), 14.3v (lead sealed), 14.1v (Gel Lead) and 13.7v (open lead). I am not at all sure which ones I have. They are Numax (Non sealed)
Now I know that the batteries are neither sealed or gel so that eliminates 14.3v and 14.1v . The batteries have been on charge for 24 hours with boost on the lowest setting and the charger says each battery is only 92% full. Could it be that I should have the charger set to 15.1v not 13.7v? I would have expected them to be at 100%. Am I undercharging them with too low a voltage?
The above figures are for the boost phase only the absorption phase lowers to 14.4v for the lead tin delphi and 13v for the open lead. 13v seems low to me however I don't want to overdrive or boil this new set of batteries.
Any comments gratefully received.
