PaulRainbow
Ok thanks. Makes total sense..
To add a little complexity into the equation I went to take a closer look at my small solar controller for the small panel. It's a Solara Fox350 and has two outputs. It says:
The FOX-350 is designed for charging 2 separate battery systems. A bistable relay provides the option of switching the charge current to the battery -the batteries are always fully isolated from each other.The relay switches the "+" string, the mass lines of the batteries should be connected with each other.(See connection plan on page 47).The 2-battery logic is only active, if 2 batteries are connected to it. Battery 1 is charged until the charging logic reaches step 3, in order to guarantee that battery 1 is fully charged.In principle, switching-over only becomes active once the battery voltage of battery 2 has fallen below13.8 V.
You could connect the solar controller to the engine and
I've been assuming you have a 3 outlet mains charger (you didn't say), but if that's not the case you can use your manual switching arrangement to charge more than one bank from mains, as you must have been doing f it's a single output charger.
