sailinglegend420
Don’t use an automotive charger on a boat - why?
- You need a high current device that will happily charge a boat service battery that is maybe 400Ah or over. This would require a charger that can deliver 100 amps. It should also have an external voltage sensor to measure the actual battery terminal voltage, and a temperature sensor to measure the battery temperature and automatically adjust the charge voltage. This is especially important if the batteries are in the engine compartment.
- You need a good Smart Multi-stage charger to properly charge and maintain a deep cycle battery bank.
- You need a charger that is designed for safe marine use where the AC side is electrically insulated from the DC side.
- You want a charger with a dedicated three pin plug, including an earth wire, not a two pin that could be plugged in with the Live and the Neutral reversed. This could kill swimmers in the water around the boat.
