Battery Charger
Waveney Boy
New Member
17 Oct 2011
Can anyone help a simple soul ? I have a Mobitronic 12v Charger on my boat. What is the "sleeping mode" button for and what does it do ?
some people find the HF noise annoys them at night . hence the unit can be switched of for a set period of about 8 hours then it starts its charging regime automaticaly.
It allows the fan to be switched off at night
Mobitronic Charger
One charger for all battery types. Thanks to their modified IUoU charge curve, Mobitronic compact chargers are quick and reliable to use with wet, gel and AGM batteries. Separate switch for selection of battery type. The starter battery terminal has an integrated charger (charging current 1A). The mute switch allows the fan to be turned off at night. With overheating and short-circuit protection. Can also be used as a power supply. Compact, light and easy to assemble.
Thanks for all your help.
So........It charges the Starter battery at a different rate ?
It is better to put into sleep mode at night ? or leave on if the noise is no problem.
