markc
Any thoughts from the wisdom of the forum?
I have a 24v 80amp Dolphin charger on the boat. Yesterday I had the stern thruster batteries replaced (like for like optima) as one of them had ruptured - this has been on the to do list for a while as the ST worked fine and I kept forgetting to do it.
Today I noticed that the charger breaker was off so I tried to switch it back on and it did go on but the charger wasn't on. I then switched off the main charger fuse to reset and then flipped on the breaker. It threw out the shore power for my supply and also the whole quay!
I'm wondering if the stern thruster batteries and wiring have some part to play in this, especially considering the rupture in one of the cells? Or maybe it's just coincidence?
As a check to rule out the shore power as the problem point, I did run up the genny, removed all other load and tried the charger, but just tripped the breaker immediately.
Any ideas what to start checking?
TIA!
TIA!
