abraxus
A possible solution would be to run the fridge via a Sterling ProLatch R - this has a "battery protection" setting which will disconnect the fridge if the voltage drops below 12.4v (adjustable). The advantage of this is that you'd still be able to run the fridge without shorepower or engine running as long as the batteries are fairly well charged, but you wouldn't have any risk of the fridge flattening the batteries.
Thanks, I'll have a look at that.
