battery cable
anderson
20 Nov 2002
we are going to install a new electric anchor windlass 1000w, distance from battery to windlass about 6mtr, battaries are 95 amp, what dia and constrution cable would we require re andy.
claymore
18 Jun 2001
In the far North
Have a look at the anchor winch thread I posted on Scuttlebutt a couple of weeks back - it will almost certainly tell you that you need a bigger battery for starters - (150 ah recommended by lofrans)
regards
Claymore
oldsaltoz
4 Jul 2001
Australia, East coast.
G'day anderson,
You will find the information on the site listed below, along with a heap of other electrical cable information;
<A target="_blank" HREF=http://www.outbackmarine.com.au/choosing.htm>http://www.outbackmarine.com.au/choosing.htm</A>
I hope this helps
P.S. Please fill in some more information on your profile, it will help us help you...
Andavagoodweekend___Old Salt Oz___/forums/images/icons/cool.gif
claymore
18 Jun 2001
In the far North
Aw c'mon Oz - the electrics will be different in the northern hemisphere surely - even the water goes down the plug a different way.
regards
Claymore
colin_jones
17 Nov 2001
Lyme Regis, Dorset
Have a look in the PBO index of articles. They have covered power windlasses as a DIY project a couple of times.
If you cannot find it there, PM me and I'll try to dig out the hard copies from the labyrinth, which passes for our office filing system.
pvb
UK East Coast
Cable size...
Your minimum size would be 25 sq mm cable, which would create a voltage drop of about 1 volt (the maximum you could tolerate). Better choice would be 30 or 35 sq mm cable. Use multi-strand copper, tinned if you can get it.
Be sure to fit a fuse or breaker at the battery end of the cable!
byron
RIP
UK -Berks
They have electricity in the Antipodes? Jeeze! Well! you live and learn. I guess that's a sign of the times, next thing they will be wanting independance just like America is trying to get by burning our tea and taking a dump in Boston harbour.
http://www.alexander-advertising.co.uk
tom52
23 Sep 2001
Thanks Oz
I have just looked at the site you recommended and its full of good info about boat electrics. The search facility answered all my questions about winterising different battery types.
There appear to be lots of other articles about 12 volts answering question I didnt even know I had !
i used 35mm welding cable from the local engineering sundries store. it has worked ok for me - no signs of heating up under usebut the pukka stuff would be tinned, so i may have problems in a few years time.
i installed a 90 amp trip at the battery end of the circuit. this has tripped out a few times in use.
battery size is not too important if (like most people) you use the windlass when the engine is running
re-inforce the mounting area well, and take precautions to protect the area between the bow roller and the windlass against chain lash.
Johnjo
8 Sep 2002
I have also used cable from a heavy duty Arc welder on my boat, but mine
was tinned, nice stuff to use very flexable and lie's flat on it's own
accord,
mike
oldsaltoz
4 Jul 2001
G'day Byron,
Yes I can confirm we do have electricity down under, we even have a moderate cricket team. (falls of chair laughing)
End of message.
Avagoodweekend, Old Salt Oz. /forums/images/icons/cool.gif
byron
RIP
UK -Berks
Cricket? What's Cricket? Over here Cricket is a Grass Hopper. Any Digger should know that. /forums/images/icons/wink.gif
claymore
18 Jun 2001
In the far North
Payback time
We send you over there in the first place because of your behaviour, to that lovely sunny place, then all you do is sit around in the sun all day practicing cricket and then give us a good stuffing when we come over to see how you are.
Gratitude.
Anyway - will the Rugby World Cup see the Southern hemisphere getting stuffed by the north or were the recent results the result of your guys having had a hard season and not sending your best team anyway?
regards
Claymore
