Battery behaving badly!
gary111160
25 May 2006
Boat in Port Dinorwic, North wales
I have just removed the battery from my recent purchase which has been laid up since 06.
Assuming it was probably shot I thought I would charge it to see. But my tester to the right terminals, nothing. Connected charger and get a fault reading saying wrong polarity! but have connected positive to positive etc. So when I connect the wrong way round, positive to negative etc it seems happy and starts to charge! Two days later it appears to have taken a charge and the tester is happy with its health as long as its connected positive to negative.
How can this be! checked charger and tester with other batteries and all fine so its the battery. Is this a sign that the battery is goosed or am I missing something?
The boat terminals have no markings on them and both are black cables, but one lead has the isolater on it so must be positive and the other cable is ground to the engine block so must be negative. I don't know how the battery was connected up to the boat as I did'nt take note.
Any thoughts?
Gary
That is not unherd of. A totally flat batter can be make to take a reverse charge. It will never be the same again.
New battery time, worth checking the cables though too.
Make absolutely certain you connect it with the polarity correct. Get it wrong and you will toast the alternator diodes.
