Grehan
Thanks for the useful guidance I got from my previous question http://www.ybw.com/forums/showthread.php?t=269487
Moving on from that I've now got the two 250Ah batteries installed (all battery link cables are very heavy duty) and they're working fine, so far as I can tell. I am, however, not sure that they way everything is wired up is exactly how it should be, so I'd be grateful if you vital sparkies would take a look at the following circuit diagram (I hope it's clear) and comment.
Key
C - 110Ah cranking batteries for starter and bow thruster
D1 - 110Ah domestic batteries (existing, before addition of D2)
D2 - 250Ah domestic batteries (aft)
SW1 - key type isolation switch, starter+bow thruster
SW2 - isolation switch, separates D1 and D2 (to allow Alternator Isolator to detect and charge separately when engine is running)
ISOL - Studer MBI 100/3IG 100Ah 3 feed isolator
ALT - Prestolite 14v 110Ah alternator
STR - starter motor
CHGR - battery charger
INV - inverter
I don't doubt it could be improved with some electronic gizmos, at a cost, but right now I'd just like any general comments on what's there, or suggested simple improvements, especially from the point of view of engine or battery charger charging. Thanks.
Key
STR - starter motor
INV - inverter
