Batteries and testing
smudge837
13 Apr 2008
Liverpool, uk
I have a 110 Ahr battery that is reading 12.73V on my hand held meter. Seems to work internal electrics well but does no have the power to crank the starter.
before I run out and buy anew battery, is this terminal or will a long deep charge at home sort it?
It is a sealed maint free type. so no hydro test.
the boat was on the hard for 18 months till I bought her this summer, the batteries were flat dead but this one came back with a charge. now I wonder if it's time to get the wallet out.
Any advice welcome.
regards
Smudge
Any advice welcome.
regards
Smudge
If it reads 12.7 ish after resting ( no charge or discharge ) for at least 12 hours it is fully charged. Monitoring over a period of days or weeks will show how well it retains its charge. A good battery will take several weeks to fall below 12.5 with no load
It does not however give any indication of its current delivering ability.
If it does not crank the engine properly I would firstly check and clean all connections including the negative and
investigate the possibility of volts drop across switch contacts or even crimp joints.
Then check the battery with a "drop tester" for its ability to supply a high current or take it to a battery depot for professional testing.
allowing the batteries to go dead flat and not recharging will have done them no favours. You might consider a new starter battery while squeezing a season or two's use out of the old ones for domestic use
Monitor the voltage across the battery terminals themselves - not the leads or connection lugs - while trying to crank.
You'll probably find it collapses almost completely immediately and recovers very quickly when load removed. Batteries left dead flat tend to develop a high resistance barrier layer between the plate grids and the active paste. They may take some charge and display reasonable open circuit voltage but will be unable to supply heavy currents.
No reliable cure but if you have facilities you could try charging at a high rate say C/10 up to about 15V then holding at that voltage for say 4 hours.
Alternatively try a desulphation gadget.
Somebody was appealing recently on here for dead batteries to try one out on.
Nothing to lose!
If you do need to buy a new one then beware the pitfalls for the unwary, which from your question it is reasonable to assume that, here is an article which is very informative for all of us, I am not technical enough to make a link to something on my pc so will copy and past it in two parts:
Part 1.
What is the best battery to use for an auxiliary charging system?
I keep getting asked this question all the time, when being asked which is the best battery. I refer to marine or vehicle auxiliary charging batteries or domestic batteries. To say there is a lot of confusing literature about this subject would be the understatement of the year. The information in the literature tends to be correct, but it's the bits which are not in the literature and the customers' assumptions that cause the confusion and hence the problems. I will try to answer the question. But in order to save you time, I suggest you adopt the following attitude and make the person trying to sell you these things answer the questions below.
The key question
Another way to approach this subject is the simple Irish way (being Irish myself). I went onto the web and obtained 3 different battery type prices, these were the first prices I came to and have no reflection on any company. I was looking for about a 100 amp hour battery.
* 100 amp hour leisure. Normal open lead acid (so called leisure) £49.99
* 100 amp hour AGM = £175
* 100 amp hour Gel = £265.59
So in my simple mind the AGM is about 3 times more expensive than the standard one. And the Gel, about 5 times more. So the question is; if these batteries are 3 – 5 times more expensive than the standard one, what do they do that is 3 – 5 times better? Do they last 3 – 5 times longer? (I think not, more like the reverse). Do they charge 3 – 5 times faster to reduce your engine running hours? (Only in their dreams.) So rather than ask me weird questions; please ask the sales man, who is trying to sell this stuff for cycling, exactly what you are getting that is 3 – 5 times better than standard lead acid batteries. Then please let me know as I could do with a good laugh.
The brutal truth about marine leisure batteries
There is no such thing as a marine battery. If you see a marine label on a battery it is simply words and may as well say Mickey Mouse.
For cost and performance open lead acid batteries are king. All other batteries are a derivative of this, with variations to suit different markets, where there are specific problems implementing the standard lead acid battery. E.g. Gel, is a standard lead acid battery except that the acid has been transformed into gel. But by solidifying the electrolyte, you introduce many problems not associated with free flowing water based batteries.
“Most expensive is best” This is so not even close to being true. In fact I would say the reverse is true in the marine leisure market. When reading all the sales literature regarding Gel/AGM, please note that none of their curves and claims refer to standard lead acid batteries. (They know better). They never claim they have better performance than standard open lead acid, this is just an assumption on your side. They claim weird things including longer shelf life and that you can turn them upside down and have your dinner under them. Who cares? I want fast charging, long life, plus good value for money from my batteries. I don't want to sit and watch them on a shelf for a year and have my dinner under one.
If a statement says that this is the best battery. The question is, best at what aspect?
If the term 'maintenance free', is on a battery, then treat this with caution. There is no such thing as maintenance-free, all batteries are basically the same. A Gel, sealed lead acid and AGM are all only maintenance-free because of the reduced charging performance curves; and not because there is something special about the battery. If you charge a normal lead acid battery to the Gel or AGM curves, then they would not require maintenance either. Remember 'maintenance free' is a handicap to fast charging not an advantage. This feature, which on the surface looks good, is, in most cases the worst feature that you could possibly buy; as this feature dramatically limits the maximum charging characteristics of the battery.
Fast charging costs water, i.e. if you want to charge you batteries fast, don't touch a Sealed/Gel/AGM etc with a barge pole. Fast charging will result in a certain % water loss from the battery. If the battery is sealed the water loss cannot be replaced. REMEMBER FAST CHARGING AND SEALED/MAINTAINCE-FREE ARE A CONTRADICTION OF TERMS. You may not like this, but tough, it's the way it is.
Watch the term leisure / deep cycle as it simply does not exist. The standard, so called, leisure batteries, are simply starter batteries with extra support for the active lead material. This may increase the life by 5 – 10 %, but does not turn a starter battery into a deep cycle battery. True traction (deep cycle) are not available at a sensible price and are uneconomical to use for standard leisure use. However, if you plan to live onboard or travel the world then do look at 6 V or 2 V traction and build your battery bank up from those batteries, but expect to pay about 3 – 6 times the price of so called standard leisure batteries. On a daily use cycle, the standard so called leisure battery (which is a starter battery) will last you as little as 6 – 8 months whereas traction would last 15 years. But on a leisure rating (2 weekends per month and about 4 weeks’ holiday) then you would get about 5 – 7 years out of a standard leisure. That's if you charge it right using advanced regulators and constant current battery chargers).
Battery sales companies quote battery cycles such as 6000 cycles for the battery. This looks good on the surface, however it will be 6000 cycles at say 10% discharge. This is a meaningless figure. All batteries have a manufacturers' graph, which odds are, you will not see in full; as the embarrassing section tends to end up on the advertising company’s editing floor. The graph will have % discharge on one side and cycles on the other. This graph is sometimes shown on glossy battery information, but is normally censored at about 30 – 40% discharge, where the figures can still show 4000 cycles. What they fail to show is the 100% discharge cycle (which they of course say you should never go to and I am not for one moment suggesting you should). This, at the end of the day is the only ultimate datum point. Whichever battery performs the best at 100% discharge, will perform best at 50% etc. The interesting fact is that they are all about the same, that is, because they are all basically the same battery. A Gel and conventional starter battery go down the same production line until one has a gel substance put in it and the other liquid. The shock with this figure is that for Gel, Sealed, or leisure, etc, the constant figure is about 30 – 60 cycles, whereas true traction with thicker plates is over 300+. (However, don't expect to see this graph on glossy literature, as they are way too frightened of this graph and will not release it). It is however available from correctly specked commercial batteries.
So which is the best battery for standard domestic leisure use?
The job I am referring to is for auxiliary charging systems on boats, camper vans or vehicles. I am not getting into what each and every battery type is best at, or for; as each type has a market, it just maybe not this market.
Part 2.
To pick the best battery for your job, then at least understand how they work. Forget the actual chemical formula and all the fancy terms around. The bottom line is that lead acid batteries have been around since the 1st World War and the basic principles have changed very little since. The only thing we all agree on is that they are not environmentally friendly, but are cheap to make and will remain king until such time as someone comes up with a solution which can compete. Which by the way to date they simply have not. How do I know this? Well it’s very simple, if they had, the lead acid battery would be out the door so fast its toes would not touch the ground.
So how do they work?
Let’s understand the basics. They are all lead acid, but fall into 2 basic groups. A starter battery and a traction battery (fork lift truck, true deep cycle).
Type 1 (starter batteries). A battery is simply a bucket of energy. If you wish to get the energy out fast, to start an engine (cold cranking rating) then you need a large surface area (large plate size). The only way to get a large surface area into the bucket, is to make the plates thin, so they can squeeze into the bucket (this is your starter battery; it needs the cold cranking kick in order to start the car, so its plates are thin to achieve this). This theory is pushed even further with batteries which increase this surface area more, to make what are known as high torque batteries. These deliver even higher cold cranking, by putting the plates in a 'swiss roll' configuration, in order to make them thinner and increase the surface area. This is good for cold cranking, but has a fatal flaw when it comes to fast charging. (The problem is, it works too well when charging and destroys itself).
Type 2 (traction or fork lift truck batteries). These batteries are not interested in the cold cranking kick, which is required for a starter battery, but are still interested in the power in the bucket. So they can reduce their surface area of the plates. The good thing about being able to reduce the surface area is that you can make the plates much thicker. The end result is you still get the same power from the bucket it is simply delivered at a slower rate.
So, for deep cycle and long life, the traction batteries are by far and away the best. But their price tends to kill them. However, if you are doing a long journey around the world, or going away from the UK for 2 years plus, then investing in 2 volt or 6 volt traction batteries is a must, regardless of the cost. They will pay for themselves many times over. For general leisure use they are the best, but a bit of a waste of money, unless you intend keeping the boat for 15 years to get the use out of them.
So what's the end result of these two battery types?
A battery is made up of lead plates, with a lead paste on the plates. Every time the battery is used, then so many bits per sq inch fall off the plates, if you have a large surface area then a large number of bits will fall off. Then to make matters worse your paste is thin so you cannot afford to lose the paste. However, if you have a small surface area and thicker plates the same is true, but the plates are thicker and as such, you can afford to lose a small amount of paste. In a nutshell, that is it, or be it in very simplistic terms, those are the differences between traction batteries and starter batteries.
__
As you can see from the above 2 battery types, the plate configuration cannot be blended. If for starting, you have a large surface area of thin plates, for traction you have a small surface area of thicker plates. One is black and one is white, there is no grey area. So, if you are purchasing a battery and it has a cold cranking rating and the salesman says it is a deep cycle battery, but will also start your engine; then it is in fact a starter battery (end of story).
What we want now is the best for general leisure
Having understood the 2 basic types then you need to ask yourself: what do you want from the battery?
Most people want
* to charge their batteries as fast as possible in order to reduce their engine hours
* to pay as little as possible for the above
* to get about 5 – 7 years use as a leisure battery (2 weekends per month and about 4 weeks’ holiday per year).
If you are using your boat for leisure only, then stick to low cost lead acid so called leisure. If you want to turn your boat upside down for 5 seconds then the Lead Acid range with sealed removable caps would be a good choice.
If you want to turn you boat upside down for an hour or two then a Sealed Lead Acid would be worth looking at. However don't expect to charge them as fast.
Having had my so-called opinion published in a UK. boating magazine (boy, do Gel battery suppliers love me. I was taken off their Christmas card list), a Dutch magazine ran with it and the response was very good. The UK magazine did not follow up the article, however the Dutch magazine called ‘Zeilen' did. (The editor is Ruud Kattenberg.) They took the article and not only published it, but ran with it a lot of questions to their readers on their web page. They received over 500 responses and were able to confirm all my findings and published the results. (Not that I need any confirmation as we do this for a living, but it's always nice to have an independent source for folk who doubt you). Is this not what magazines are all about, trying to help the people who buy them and have a bit of a dialogue going?
Conclusion
The best battery to use for fast charging using advanced charging systems
* For general leisure use: use low cost Lead Acid which can be topped up with water. So called leisure batteries
* For long term cruising then use 6 volt traction
Avoid Gel / AGM for 3 reasons
1. very expensive
2. their fast charger rate causes them to gas
3. poor cycling numbers.
I notice you are in Liverpool. If you want I'll check your battery for free tomorrow (Sunday) at the Marina, I have a professional battery tester, a proper top of the range thing.
That well known article has a lot of truth in it but is not valid when he vents (accidental pun!) his prejudices about AGM batteries. He is simply wrong and out of date.
Nonetheless for most people I agree his conclusion that traditional flooded batteries offer the best value and are the easiest to look after.
That's from Sterlings website .... No need to do anything clever to make a link just paste in the URL .... the forum software will make a clickable link out of it for you:-
http://www.sterling-power.com/support-faq-2.htm
the little insert link icon,
will enable you do make a "clever" link
This this:- See here
Hi, I will be down
Hi Savage,
I aim to be out tomorrow for the racing. If you are going to be down the marina, I am on Ta kymata opposite day dream believer BB08.
I know it might not help but I will be the red santa looking guy in the bar around 12 ish.
cheers
Smudge
AKA James/ Jim
Batteries
The person who wrote that story on batteries is obviously a journalist (or wants to be).
I hate the way they decide on a line for the story then exagerate as much as possible to support their contention.
Obviously it is not nearly so black and white.
I do agree that price is most significant. Batteries for cars must be cheaper simply because of more demand and more competition. probably explains why anything with marine in the name is more expensive.
I would not pay top dollar for a supposedly best battery. On the other hand it is no good buying a battery type that will not satisfy your needs.
So to the OP just look around listen to everyone and decide yourself. Yes your starter battery is probably dead but do the volts test on the battery posts with starter try to turn engine over. If voltage drops below about 9v battery is dead. If voltage holds up wiring or solenoid is bad.
good luck olewill
Thank you for that, I did not realise it was from sterling power website, at least forgotten if i did, or I would have copied and pasted the website link to it, but I have got the article as a word doc on my pc. but even so, where do I find the insert link icon? can I do it from a word doc also.
Very true, and agree re AGM, but even though i have been buying batteries for years the information opened my eyes on the subject, and i thought it appropriate for the guy raising the question, he buys with more knowledge than he may have otherwise.
The "insert link" icon appears above the text entry box if you have selected the " Standard editor" in your User CP.
Go to your CP
Find "Edit options" from the list of things down the left hand side.
Scroll almost to the end of the the options you can change.
Change "basic editor" to "standard editor" and save the change.
You will now have loads of new formatting and other bells and whistles to play with.
Copy and paste is the way to do it from a word document on your own computer.
Go to your CP
Got it, many thanks.
The link above has been brought up on here many times and, in the past, I have agreed with the logic. I now think it is out of date. When I looked at batteries 4 or 5 years ago the prices were as he described. Now it the best price I can find for a 115Ahr leisure is ~£80. A Trojan 115Ahr is now £150. Using the Stirling logic it would seem Trojans are the way to go.
Allan
