sailaboutvic
Details .
Charger victron 45A ,
The Charger as two set of charging lead , one to the starter and one to the house battery
Three house battery , one starter battery ,
Seal acid.
Starter battery hasn't been used for some weeks , but the charger on has we charge the house battery each day ,we using then all the time , full time on board .
I notice the starter battery was hot to touch yesterday , once it cool down I removed it and tested , V 10.9 guess I can say good bye to that .
What I forgot to do is check if the house battery where also hot ( stupid ) as there are keep else where .
House batteries 12.9v this morning
The question is what would cause the battery to get hot , ( shorting of the plates , lack of water ,
Over charging ) ?
I would assume the charger would know the starter batter was fully charge and just charge the house batteries .
Don't want to stick a new battery on before I sure that the problem was the battery and not else where , any suggestion?.
Having to replace it what size battery for a 50HP engine would the panel suggest , it had a 110AH but it doesn't need to be that big , Volvo manual doesn't give size .
Thanks .
Seal acid.
Over charging ) ?
Thanks .
