vas
hello all,
since MiToS will stay on the hard for another 6m I'm planning to do a few more things that I would originally postpone for next year.
So, bathing platform is #1 in the list.
MiToS originally had no bathing platform as per the 70s boats, and featured a v.well engineered and designed alloy ladder that was fixed on a couple of mounts on the aft deck.
At a later point PO built a joke of a platform around 90cm wide (as in deep/long how you wish) for the full beam (around 3.6m down there) made off 20something mm ply featuring a series of random and non-aligned 50mm holes
Pretty awful
Frame mounts were a real joke with 18mm ss thin wall tubing (3 out of 4 mounts were cracked and platform was mainly supported from two top mounts and boarding ladder.
Ripped them all out, looks like I wont be keeping anything of that lot.
Plan is to have a 1.4m-1.5m long platform again for the full beam of MiToS.
Would like to support it from underneath on the two 1m long beams where the trim tabs are mounted.
V. strong and decent spot for the mounts.
Plan with frames looks like this sketch:
Was thinking that in section the 3 supports could look like that with the lower slanted ending aligned with the support points and the top part of each section "cutting" into the platform material.
Actually this setup would work if I had beams of solid teak (or mirande, or cedar or whatever) at 20x25mm running bow to stern. Then each beam would be supported laterally from the 10-14mm bits of ss coming up. The right hand side one on the sketch (rear end of the platform) V shaped would be capping the whole construction keeping the beams spacing right. Doh, reading it, it's not at all clear, need more sketches
However, since having a bathing platform made of solid teak or whatever strong enough timber is going to cost me a fortune, I have to think of alternatives!
Series of Qs:
Assuming I dont want solid deck with caulking, what is the acceptable gap between pieces of timber to step on barefoot. I'd say for 25mm material I could get away with 10mm gap. Agree or should I stick to 5-6mm? Remember talking smallish kids playing about there, dont want to have broken toes and legs there!
Alternative ideas on constructing a 3.6X1.5m platform? I don't want a GRP construction for many reasons.
Happy to have a strong ss frame supported as per the plan and filled up with ply+9mm teak+caulking.
Happier to have a more dense ss frame and 20x15mm solid teak or cedar without caulking around...
Ideas?
cheers
V.
Pretty awful
Series of Qs:
Ideas?
cheers
V.
