Barometers, Hygrometers & Thermometers
Babylon
7 Jan 2008
Solent
My old cheap kit - inherited and mounted on the ubiquitous teak panel with faux-brass corners - has now all failed. The hygrometer (what measures humidity) is 30% below true value and cannot be re-calibrated because the screw fell off, the barometer jumps about like a sick locust and the thermometer reads seven degrees low and also cannot be calibrated.
Question is whether to fork out for fancy Wheems & Plath separates at £85 each (which curiously work out at exactly £1 per mm of diameter):
http://www.piplers.co.uk/cabin-and-...ions/weems-plath-endurance-85-brass-barometer
and: http://www.piplers.co.uk/cabin-and-...s/weems-plath-endurance-85-brass-comfortmeter
or go for an electronic version which records and displays trends etc, the choice being:
VION: http://www.force4.co.uk/force-4-electronic-barometer.html#.VQdKd2SsWPU
or NASA: http://www.force4.co.uk/nasa-meteoman.html#.VQdLA2SsWPU
Does anyone have any experience of using this electronic stuff?
Of course the broader question is this: does one - in these days of NAVTEX and inshore internet info - actually need the information these instruments provide for coastal cruising and occasional offshore sailing?
I don't know, but my Casio watch gives a better pressure reading than the barometer on the bulkhead, even if it doesn't look as good.
There's stacks of electronic weather 'stations' about. We have one that shows pressure plus trends, inside and outside temp and relative humidity plus has a radio controlled clock as well. Got it on a special offer at a Greek lidl a couple of years back. Does the job. However, we also have a Plastimo barometer and my Dads barograph, neither of which is anywhere near as accurate as the Lidl setup but much better looking!
At home I have one of the same as nigelmercier mentions above..
On the boat I went with function - if you go to Amazon and seach on "outdoor barometers" you'll find a whole load suitable for an outdoor/garden environment and I took the view they'd be perfect for the boat... same with clocks/thermometers and etc
I moved the (traditional) barometer from the main bulkhead to the chart table, so I could at least read it and note it in the log. I haven't calibrated it but it does go up and down - and keeping an eye out for rapidly falling pressure is the main thing, isn't it? I then bought a decent clock to cover where the barometer had been - and yes, it is also very useful as Mrs H almost never wears a watch :(.
I too have a lidl weather station on my bulkhead. Appears accurate up till now. Gets the time signal from Germany so its an hour out. I do take it home after each trip as I doubt it would last long in a maritime environment full time. Bargain for a tenner.
